87grand am 2.5L no fuel at TBI
Discussion in 'The Lounge' started by R72K5, Sep 25, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    having problem of no fuel getting to TBI unit on 87 grand am 2.5L, cant hear pump priming either, car ran and was parked a few weeks ago with no problems and now its not pumping fuel, theres no reset button in the trunk on at leats these older FWD cars and the ECM and pump fuses are fine, i think gray and purple are the colors of the two wires going back to tank
    who knows what on these ? cutlass calais and other cars like this are basically same thing as far as fuel ssystem and so forth
    thanks
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    how about the fuel pump relay? do all the electrical accessories work? if the accessories dont work, possible ignition switch, try swapping relays around underhood to see if pump works..
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah i was just thinking about relay, yep, hmmm.....
    ny ideas how to find out which is fuel pump relay ?
    something soemhow happened since the car was parked, dunno what, hmm..
    thanks
  4. Confedneck
    Nov 1, 2002
    5,236
    relays go bad...have someone turn the ignition on while you listen/feel the relays under the hood, when you find the one not clicking, swap it with another..try again...
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool, yep thats what i need to do and hope is whats wrong, i found two relays so far jnust by digging around in here, as long as the numbers match then i should have no problems swapping them around
    thanks
