87tbi converted to carb?
Discussion in 'The Garage' started by bigbadchev84, Dec 16, 2004.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have a chance to buy an 87 fuel injected 350, if i do get it i would have to set it up for a carb, can i use a standard alum sb intake or do i have to get the special one with the center bolts straight up and down?
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Could I ask why you "have" to switch it to carb?
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'll take that tbi setup off of your hands when you swap.:thumb:
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have an 83, and the motor has no wiring harness or the brain box
  5. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    does it require a special intake for carbs, or will the on off my 76' 350 work?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The centerbolt heads have a slightly different bolt pattern. You'll either need a special intake or you'll have to modify yours with a drill bit.
