88 350 into a 78 p/u
Discussion in 'The Garage' started by 84CUCV, Mar 11, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I have been told by a number of people this is not worth doing. I wanted to hear what some of you think. Motor runs good and its free if i want it. Just need to find wireing somewhere for it. maybe painless? So, what do you guys think stick with a carb or should i got for it. Right now i am up in the air about it. as always thanks
  2. goldwing2000
    goldwing2000 Guest
    Wish you were closer. I'd swap you my carb motor for that TBI one. My p.o. converted my '89 to carb. :doah:
  3. dyeager535
    26,982
    191
    Absolutely worth it, as long as you are up to the wiring and other issues.
    There is nothing like knowing no matter what the temp it will start with no problems, you'll never have to mess with a choke, you are getting better overall performance, and so on.
    All that can be done with a carb in REALLY good tune, but most carbs aren't in so good a tune that you can't tell one from a fuel injected motor. :)
    If wiring is the only issue, great, not THAT much expense, but you start talking fuel lines, pump (for instance) and expense starts to climb.
  4. goldwing2000
    goldwing2000 Guest
    Also keep in mind that the flywheel/flex plate and torque converter/clutch are different. You'll need to get those parts from the '88 donor.
  5. dyeager535
    26,982
    191
    and the costs potentially start to rise even more... :)
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK does anyone make a wireing for this? the truck it came out of is now gone. The truck it might go into has a sm465 and a 203. thx for the replys
  7. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Something like this?
    http://store.summitracing.com/default.asp?Ntt=painless+60201&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115&target=egnsearch.asp
    Not cheap! That's the 4' longer version of two otherwise identical harnesses, and with the large full-size engine compartment, that's probably the one you'd want. I'd be interested in reading feedback from previous installers, and painless would probably answer any questions.
    http://www.painlesswiring.com/webcatalog/cat-fiharn.htm
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks for the links. Some good info there
