88 6.2 diesel motor That I am looking at...
Discussion in '1982-Present GM Diesel' started by 84CUCV, Dec 15, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Other then a manifold, injection pump. It is a complete motor. He said I could have it for 200. So I am thinking something must be wrong with it. He wants it out of there. The crank turns. I don't know what else to look for? Any help would be appreciated. Thanks Mike
  2. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    If possible pull the oil pan and check the main webs for cracking near the outter main bolts.
    I recently pulled the motor down on my old ex-air force '88 crew cab. It has 80K original miles and was starting very hard cold due to low compression. Everything was looking good until I found #3 main web cracked /forums/images/graemlins/angryfire.gif. Up to that point it was just going to be a re-ring job. I bought the truck with 42K on it and it didn't start good then when below 35*F. Nearest I can tell it wasn't properly broke in and the rings glazed over.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks again dieseldan Mike
