88?-91 seats in an 82
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigJohnson, Jun 19, 2002.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    What was the first year for the sliding passenger seat, and will this bolt in an 82 model with no modifications?
    Thanks,
    BigJohnson
  2. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I *think* 86 or 87 was the first year of the sliding seat bases. Someone tried to throw them into my 84 and drilled into the floor (bad idea) to bolt them in. It was all ghettoed up. I wouldn't try to "fit" a newer seat base onto an older floor.
  3. dyeager535
    26,975
    No they won't fit without mods. The passenger seat that hinges forward but doesn't slide (early) uses the hook to keep it on the floor in the rear, the sliders use a conventional floor setup, like the drivers side.
  4. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    i just put 88's into my 86. Had to drill 8 new goles for them to fit but the new seats are really comfortable, it was definetly a worth while swap.
  5. 8BaLL
    8BaLL Registered Member
    Jun 13, 2002
    64
    Northwest Missouri
    Did you get the 88 seat from a junk yard? How much did you have to pay for them? Was the installation difficult and how long did it take? I cant stand the seats in my 85. I hate having to sit straight up in the air because they will not recline.
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I put some from a 1990 in my '74. I retained the stock brackets. I cut a 1/8" piece of plate that was 17"x17" square. I stitch welded the stock brackets to the plate. Then I drilled the mounting holes for the seat through the plate and bolted them up. I had to modify the lift lever for the back of the passenger seat so that it could recline (still fucntional and works well). Keep in mind, that the new seats will make you sit about 2" higher than your stock ones because of the differences in mounting (I like sittin ghigher anyway, better line of sight when wheelin'!! /forums/images/icons/laugh.gif ). But if you want to retain you stock mounting brackets, that is the way to go. I can post pics if you are interested. It was a VERY worthwhile swap.
  7. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    Yes I'd like to see some pics. I've been wondering how to get rid of the seats in my '84 for the newer adjustable ones.
    Dan
  8. Ben Malinski
    Ben Malinski Guest
    I installed reclining buckets from a 1990 Ford extra long club van. Arm rests also. The door close even with the arm rests but for a few months it was tight and then they "formed" to the door. Very little mods were needed. Get some angle iron, drill and cutting torch and make the brackets. I used the exsisting brackets from the original 84 blazer seats and mated them to the new ones.
  9. wakedog
    Mar 7, 2001
    233
    Minnesota
    well i got my seat form a friend who was parting out his blazer, i paid $90 front and rear which i think was a great deal cuz the seat were absolutley perfect, and it prolly tool and hour to install
  10. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Hell of a deal!! You can't get a set around here for less than $300-$500 (full set, front and rear), and they still might need to be reupholstered! /forums/images/icons/shocked.gif
