88-98 solid axle swap kit
Discussion in 'Suspension | Axle' started by k5 krawler 50, May 14, 2006.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    sold
  2. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Here are some pics. The kit looks tarnished for some reason, but its not, i think its the camera not taking a clear picture. Anyways here are the pics, and i forgot to mention that this kit has never been installed and ran, and it also comes with a set of shackle sides. You can also run 52 in springs by flipping the front crossmember around. Thanks for looking.
    Cory
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    That looks pretty good....hope mine can come out like that.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  5. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    Hey, krawler, is this for a 2wd to 4wd conversion, or is this only 4wd IFS to 4wd SFA converstion???
    Also, what springs does this setup require for the front? 52"'s? 56"'s? Other?
    ***Edit: Just read for 52" springs if it's flipped.... If it's not flipped, what does it use?
  6. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    It was set up to be ran on a 4x4, but i believe it can be ran on a 2x4 also. The reason i say that is if the front of a 2x4 frame has the same bolt hole pattern for the bumper as the 4x4 frame then it should work with the front crossmember/spring hanger, and the rear shackle hangers can be hung to your prefrance of shackle angle. Also with a 2x4 frame no matter what kit you run, you will most likely have to notch the crossmember.
    As for the other springs, you would run the 47" lifted springs for a 73-87 truck or blazer.
  7. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    Could they fab up a kit for a 01'+ HD for around the same price? I'd like to do my D-Max sometime :D but ORD's seems high for all that it is.
  8. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    i actually do not know. I could probably get the shop info for you tomorrow if you want?
  9. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
  10. 1967k10
    Nov 21, 2005
    1,728
    That would be great. Thanks
  11. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    TTT.. New Price... 400 plus shipping.. i need this gone soon. Thanks.
    Cory
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    does it use 73-87 springs, or 88-91s?
  13. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    could you do me a favor and measure from the arrow to the very bottom/back of the bracket, to know how far inboard the shackle would be, thanks
  14. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Beater: you can use the 73-87 lifted springs ( the ones for 88-91 k5, sub also apply) or you can use lifted 52" rear springs.
    Cajun: That measurement is: 5-1/4" with out the bushing and 5-1/2" with the bushing. hth..
  15. Cajun4x4
    Oct 17, 2005
    889
    Lafayette, LA
    thanks man
