88 Blazer Axles?
Discussion in 'The Garage' started by K5HIGH, Sep 1, 2005.
  1. K5HIGH
    K5HIGH 1/2 ton status
    Dec 8, 2004
    102
    harrison twp. mi.
    Just currious if anyone knows off hand which axles I have in truck? has factory 10 bolt with 342s 28 or 30 spline? Its an 88 k5. thanks
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    probably 30 spline. thats what i've been told anyways
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It should be 28 spline, 89 was the first year for 30.
    spec's
  4. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Agreed.. unless it was swapped out, it should be 28 spline
  5. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    sorry i forgot that it started in 89 not 87
    now i feel retarded
  6. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    Thanks for the info, now im trying to figure out what i broke in the rear. About two months ago i heard a noise form the rear like a pop and then fluid was dripping out the bqack cover. well i took the cover off and there was a tooth laying in the bottom of the rear end. It must of broke off and flung into the back cover and put a hole in it. i apoxyed the cover, filled it back up with fluid and its been fine ever since. Until recently had it four low jumpin on it preety hard and pow ther rear took a ****. my buddy seems to think its the spider gear and the ring and pinion. any advice would be appreciated as i am in the process of tearing it apart and dont have a ton of cash. thanks again guys!
  7. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
  8. dyeager535
    26,982
    191
    what did the tooth look like?
    Side/pinion gear teeth are "straight cut", while the ring and pinion teeth are both curved.
    It's likely going to be easier, cheaper, and quicker to find another axle, unless it's a side or pinion gear that broke and that's all that's wrong, and you have another donor parts axle in excellent shape laying around.
    Typically you get into them and if open, the thrust washers for the pinion gears are shot, which eats into the carrier and the pinion shaft.
  9. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    the tooth was straight cut. havent pulled the cover off yet but hoping itws not too bad in there.
  10. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    Rear end is toast. need another 10 bolt w/342's anybody have any laying around? Thanks!!!!!!!!
  11. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
  12. 8t7jimmy
    8t7jimmy 1/2 ton status Premium Member
    Mar 2, 2004
    137
    West Lafayette, Indiana
    ! Have a set of front and rear 10 bolts with 3.42 that will be comming out of my blazer. They are still in the blazer, but will be comming out soon, if your interested. The rear is a limited slip, but i have a mini spool and open carrier that will be included with axles.
    Ryan
  13. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    Id be interested in the rear if youre selling it as a whole, meaning brakes to brakes. thanks. how far are you from Detroit area?
  14. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    Also, what year rear end can i replace mine with? 84-91? any differences? thanks again
  15. 8t7jimmy
    Mar 2, 2004
    137
    All 10 bolts before 89 and some 89 blazers have 28 spline axles. After that they went to a 30 spline axle.
    Map-quest says 330 miles, 5 hours from Detroit, MI to Lafayette, IN.
    I would be selling the entire axle. Currently the ebrake cables are bad, but i have a brand new set (still in the box) of ebrake cables that i would sell, or you can use your current cables. I would like to sell the matching set of front and rear axles, but i will sell them separately.
    Ryan
  16. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    I dont think the size of the axles matter if im swapping out the entire rear end? right? how much would you want for the rear? and is it brake to brake? thanks again. also when will it be available?
  17. 8t7jimmy
    Mar 2, 2004
    137
    It is complete from brake to brake, except for the e-brake cables. I want to get $100 for the axle and $25 for the brand new e-brake cables, if you want them. I could have it out of the truck by Sunday afternoon if you want to come and get it. I would need to know by Friday afternoon, to get it out by Sunday.
    Also, it does not matter what spine the axles are as long as you replace the entire axle.
    Ryan
  18. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    Still have it? want it! please call 586-524-0816 MIKE
    OR leave # thanks
  19. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
    YOU GOT THAT #? Lets work out a time to pick up the rear end. Thanks
  20. K5HIGH
    Dec 8, 2004
    102
    harrison twp. mi.
