88 Blazer Hub Question
Discussion in 'The Garage' started by mike2891, Jul 22, 2005.
  1. mike2891
    mike2891 Registered Member
    Apr 2, 2005
    8
    East Liverpool, Ohio
    My hub is broke on my 88 blazer & I thought of getting manual locking hubs for it so I called around to a few of the parts stores in the area & one told me they had them in stock and gave me a price, but the other store said I couldn't convert it to manual hubs on the 88 because they changed something with the driveshaft? Honestly I'm not extremelly knowledged on the whole 4x4 repairing, but i'm learning as I go.. so anybody who can give me any information at all I would appreciate it.
    it's an 88 full size blazer with everything still stock....350 of course
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Go buy the regular internal manual locking hubs , you will be fine . I converted my 83's axle over , Warn Premiums . And later switched to a newer 89 Suburban front axle and the same hubs work on there . :D
  3. mike2891
    Apr 2, 2005
    8
    wow, fast reply... alright thanks a lot that was all I wanted to know
  4. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    The guy was probably refering to the change in body style that happened in 88 1/2 ton 4x4 pickups. they changed from solid axle to independent front suspension. Blazers, Suburbans , and 1 tons kept the old body and suspension til 91
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup go get a set of warn premimuns. Or Superwinch. And change them out. They may try to sell you a spindle kit but you shouldn't need one on an 88.
    You only need spindle kit if your locking hubs have only 3 bolts holding them on. If your hubs have 6 bolts you Dont need the kit.
    I would not bother rebiilding auto hubs cuz it wont last. And last time I checked new were $400-500.
  6. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    yup. Warn's will run you 50 bucks each and last 5 times as long. Just make sure you lock the hubs BEFORE you get stuck so you don't have to thrash through the mud to put it in 4 by.
    Whoever said you can't convert them is wrong. I have manual warn hubs on my 88 straight axle.
  7. mike2891
    Apr 2, 2005
    8
    Thanks for the help guys.. I went to the local parts store and picked up a set of manual hubs & put them on and the 4x4 works great now... Now as soon as I get the lift on I'll be back to muddin it again
