88' Blazer K-5 Question:
Discussion in 'The Garage' started by MuddQueenK5, Dec 7, 2005.
  1. MuddQueenK5
    MuddQueenK5 Registered Member
    Oct 15, 2005
    84
    Glenside, PA
    My u-joint and output shaft/yoke from t-case broke this morning and my driveshaft is now laying on the ground. I had a couple questions:
    Where would I purchase the output shaft/yoke from t-case? Is there an upgraded one to take the place of OEM?
    Are the upgraded u-joints worth the extra money also? The ones that are packed with syntethic grease?
    Can I replace the output shaft/yoke from t-case without dropping the trans?
    What type of trans do I have? The NP205 or 208? My car is an automatic and I believe the 2500 3/4 ton.
    Thanks! Sorry for the n00b questions...
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Questions for your questions.
    Do you have a slip yoke or fixed on the tcase? The part that the ujoint is in. Does it slip off of the tcase or is it bolted to it?
    Beefy ujoints are worth the money if you keep breaking the cheap ones and they damage the driveshaft.
    I dont think the syn grease helps any.
    Yes you can remove the tcase with the trans installed.
  3. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    I believe it's a slip yoke. Here are pictures of the damage:
    Yoke:
    U-join/driveshaft:
  4. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    its def a slip yolk and its a 208 t case. try a junk yard any yolk out of a 208 will work. the yolk will just pull out so you dont need to remove trans or tcase. also the heavier u joints are def worth it
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    and u walked outside this morning and saw it like that? :haha:
    you either have a 208/241 (88 was the transitiong year, could have either).
  6. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    hehe no no, I was driving to work this morning and felt a really bad vibration/"death wobble". Then when I went to give it some gas I heard a CLUNK and couldn't move. How would I check to see if it's a 208 or 241?
    I am told by a fellow 4X4 friend to remove the drive shaft and just keep it in 4WD to make it FWD. Is this possible? I really need this vehicle up and running in order to go to and from work, etc.
    Please double check my shopping list:
    2 - U-joints
    1 - Slip rear yolk
  7. Veefour
    Veefour Registered Member
    Jun 7, 2005
    54
    North Carolina
    That would work to get it home in an emergency, but I wouldn't suggest it for daily driving
  8. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    Well, I wouldn't be driving on it like this for a month. I would say 3-4 days max. I have two jobs so I need this vehicle to get to and from. I was lucky to get enough time in between jobs just to take out the drive shaft. It is now out, and I looked at the metal tag that is stamped on the t-case. It says 208, so I am guessing I need a 27 spline, slip yolk. Anyone local (PA area) know where I could get one at a decent price? And are there upgraded ones?
    I am also looking at the drive shaft (sitting in my living room) and was wondering how the u-joints come out? And if I purchased new u-joints would the two things that sit on the end (look like bearings?) come with it? Thank you guys so much for the reponses! :bow:
  9. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    when you get new u-joints, they should look like this:
    This is just a picture I got from online. Your box and joint will probably look a little different. I hope you get ones that are at least made in the US. :D
    Rick
  10. gmtech954
    Dec 6, 2005
    96
    ct shoreline
    i def do not reccomend driving in 4wd with no shaft with a 208. remember you have a slip yolk which will fall out and then youll start losing fluid from the tcase and probably kill that two best to just leave till its fixed
  11. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    Thanks for all the responses and technical info. Really helped me out a lot. The U-joints were easy to find and I am going for the higher end/tougher ones (only $7 more). My only concern is that locally, I am not having much luck finding the output shaft/rear slip yoke. Anyone have any suggestions? I don't mind paying a bit more for an upgraded one. :D
  12. echos
    echos Registered Member
    Nov 21, 2005
    28
    MD-Phoenix someday soon
    Try John at JBConversions. They are on the web, 337 625 2379
  13. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    I hope he has better pricing then the devil...I mean dealer. I just got a quote from them for $184 for just the rear slip yoke :mad: :mad: :mad:
  14. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I ruined a slip yoke on my 241 when I was 3 hours away from home. Welded it back together and drove home in 4wd to keep stress off of the weld. It broke again 25 feet from home. I bought a new on at the dealership for 158.00. A week later I bought a complete used shaft with slip yoke on Ebay for 60.00
  15. BROKEN-ONE
    BROKEN-ONE Registered Member
    Sep 15, 2005
    78
    kansas
    shopping list
    tranny fluid for the t-case , and a new rear t-case seal . with what i saw i would it would be good ins.
  16. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    Okay, now I am completely flustered. Me and my friends got it up and running/test drove it and everything seemed to be okay. Just as the snow hits and I had to be a bit harder on it, the driveshaft again falls but it fell where it connects to the yoke in the rear axle. The straps (w/ 4 bolts that connect to the yoke) did not break and are not broken, it looks as if the the u-joints slipped right out from the bearing caps.
    My thoughts are because we did not use the retainer clips (half moon/half circle) on that part. I was told that it was not needed since those straps (w/ 4 bolts that connect to the yoke) were there. Any ideas?
  17. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    They are required!!!!!!! I spit a shaft out of my Blazer on the way to a Gilmer run. Put the clips in next time.
  18. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yes they are. Jeeps and other vehicles have a little nub on the yoke that keeps the bearing caps on the ujoint. Now, as you can see, if those c-clips are not on the joint, there is nothing holding them in but the friction of the straps. That is not enough, cause under load, they can change shape. That would allow those to slip out. Definately need to use those clips.
    Make sure nothing got damaged beyond repair when it fell out again. And next time, ask a question here before you go off the word on one person. People her will steer you in the right direction. Wacth out, it could get expensive though :wink1:.
  19. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    Thanks guys fortunately I only gunned it only to get over a snow mound. It still broke down in my apartment complex. I got another u-joint and installed all 4 retainer clips. The only thing I am scared of now is to gun it again hehe.
  20. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    Mudd Queen, where in bucks are you?
