88 blazer to 89 pickup axle??
Discussion in 'The Garage' started by bckinblk, May 24, 2004.
  1. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    I have a 1988 k5 that I am swapping in one ton drivetrain .I also have a 1989 c-1500 2wd pickup that needs new wheels .Can I use the 6 lug axleshafts from my k5 10 bolt and swap them into the pickup 10 bolt so I can reuse my 6 lug wheels?? And how could I turn the front into 6 lug?? Thanks Also the pick up has a g80 in it and the k5 is a one legger.. /forums/images/graemlins/k5.gif /forums/images/graemlins/crewcab.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The 88-98 axles are different width I do believe, so I doubt it will fit.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yup, the shaft lengths changed with the body style. /forums/images/graemlins/frown.gif
    Easy to go 6-lug on the pickup though. Get a rear end and rotors from a light-duty C2500. Probably not worth doing just for a set of wheels... unless the rear end is on its way out, and it needs a brake job /forums/images/graemlins/thumb.gif
