'88 Blazer Wiring - Rear Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dj-beeker, Jun 8, 2002.
  1. dj-beeker
    dj-beeker Registered Member
    Jun 7, 2002
    13
    \'88 Blazer Wiring - Rear Window
    I have an '88 blazer and the back power window won't go up by using the key. I searched the forums and it works up and down from inside the cab and only goes down from the rear of the truck. Any insight to what might be causing the rear window from not going up?
    Also - does anyone have a wiring diagram for the '88 Blazers? I am having a problem with a tail light.
    Jeremy
  2. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    Re: \'88 Blazer Wiring - Rear Window
    could be a bad key switch or the plug that attaches to it.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would take the switch out and clean the contacts on it, it may solve your problem for free. /forums/images/icons/laugh.gif
