88 Burb engine swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cabledawg, Mar 16, 2007.
  1. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Cool, I got the engine in and everything is reinstalled, fluids done, all the wiring is in place. SOB cranks over but wont start. I havent done the timing yet, I will check for spark in the morning. Had issues with fuel lines, ok now, but injectors should be working (brand new). I replaced the old standard dizzy with a new HEI dizzy. Didnt accept the old harness, so I just used the power lead (the only thing the new dist needed, has coil on top). Any suggestions?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You have a wrong distributor. The ECM needs feedback from the module in order for the injectors to work and also in order for the ECM to control timing function.
  3. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    Can I just replace the coil and cap, or will the whole thing have to come out? It was a real PITA to get in.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Have to change to the correct distributor.
  5. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    Went with stock replacement from Autozone and bigger than stock coil. Fired right up. Thanks guys!
