88 K5 not running - help!!
Discussion in 'The Garage' started by SoonerBob, Nov 6, 2005.
  1. SoonerBob
    SoonerBob Registered Member
    Nov 6, 2005
    20
    Norman, OK
    Ok, I have a 1988 GMC K5 Jimmy 4x4. Lately it hasn't been running very well and has gotten progressively worse until today it wouldn't even idle without dying. It's also doing something really weird - none of the electronics (map lights, radio, headlights, anything, etc...) will work unless the truck is running. I checked all the fuses and they're OK so I'm stumped there. Next is the truck not running. I know it is starving for fuel since it will run on starting fluid but it wont run without it. I would think it would be the fuel pump that is the problem. Now the fun part - I don't know where the fuel pump is :o It has an aftermarket electric pump, not a mechanical one but I'm not sure as to where one would mount it but I'm hoping it's not on top of the gas tank. Anyone know what I need to do before I go find the fuel pump and replace it?
  2. spydermonkey454
    spydermonkey454 Registered Member
    Sep 30, 2005
    33
    lexington sc
    the fuel pump is in the tank
    sounds like you are not getting battery power to the vehicle
    but you are getting alternator power??????
    better check for voltage at fuse block
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    might try a new fuel filter
  4. absolute
    absolute Registered Member
    Apr 7, 2005
    77
    Near Spokane, WA
    Check your terminals and ground points from your battery.. Just a thought, my neighbor had a very similar problem the other day on his 86 K10... rang my doorbell and asked if I could help out... and thats what it was!
  5. SoonerBob
    Nov 6, 2005
    20
    Norman, OK
    put in a new fuel filter, still didn't work. I'll check all the terminals and ground points tomorrow sometime when I have more light/time. Thanks guys.
  6. dyeager535
    26,979
    On a TBI truck, even if the fuel pump is good, the ECM has to tell the injectors that the engine is cranking before they will fire. In other words, all ether does is provide fuel, spark is always present given everything there is working right.
    You can check for an injector pulse with a "noid" light, I'm going to guess you don't have an injector pulse.
    "crank no run" links here http://coloradok5.com/forums/showthread.php?t=141717&highlight=troubleshooting are what you can follow to troubleshoot.
