88 Oil Cooler and Hose p/n's ??
Discussion in 'The Garage' started by 88Silverado, May 18, 2003.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    88 Oil Cooler and Hose p/n\'s ??
    Took my 88 out today across a local 4 wheel trail to check things out. About an hour into the ride I stopped to stretch and noticed a bunch of oil dripping in front of truck. I looked it over and the oil is running all along the lower radiator tray and fan shroud. The lines looked wet with oil but not dripping. I looked at the cooler and its looks wet with oil too. Looks like someone had changed the lines before cuz theres 2-3 adaptors between the hardlines and hoses. Priced cooler at Autozone for $110 !!
    Does anyone know the GM part numbers of the cooler and hoses so I can do some checking around?
    Oh yea...also discovered front right axle seal is leaking /forums/images/graemlins/frown.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: 88 Oil Cooler and Hose p/n\'s ??
    if you message me with as much info on your truck as possible I can get you the GM p#s from Mitchell On Demand
  3. dyeager535
    26,982
    191
    Another idea, talk to the local hydraulic hose place.
    They can build the "armored" lines (steel covered or steel braided rubber) with the correct fittings *typically* for very cheap. I almost guarantee, if GM can still get them, they won't be cheap.
    IMO the later oil cooler lines, plain rubber hose to steel ends, similar to the AC lines, are a bad/cheap design, that tend to fail more often than the "older style" steel braided lines. Got a couple of the armored steel line setups running on a couple of different trucks, and they don't leak.
  4. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    Dude your little Picture is awesome /forums/images/graemlins/thumb.gif
  5. 88Silverado
    Mar 13, 2003
    2,664
    Thanks for the help!
    I called the local GM dealership and got a P/N of 12546251 and a price of $265 /forums/images/graemlins/eek.gif
    I then located a local radiator shop that also repairs aluminum radiators etc. I dropped it off at lunch for them to evaluate. If it can be fixed, $30 /forums/images/graemlins/thumb.gif
    I cleaned up the lines and they look pretty good. I do agree, the amount of fittings and adaptors GM uses is pretty poor design. Actually thought about replacing them with barbed ends and standard hose with hose clamps.
    I never thought about having lines made up, that a good idea.
    Thanks for the comment on the "small" picture, I guess your referring to the U-2 pic I have by my sig. Ive worked on that aircraft for years, pretty amazing what it can do.
    Ciao /forums/images/graemlins/grin.gif
  6. Grim-Reaper
    7,385
    Atlanta
    I just saw a brand new one for sale either here or in PBB for sale forum.
  7. 88Silverado
    Mar 13, 2003
    2,664
    Where did you see the oil cooler for sale?
    I cant find it /forums/images/graemlins/frown.gif
  8. 88Silverado
    Mar 13, 2003
    2,664
    The local radiator shop was able to heiliarc the crack then flowed a high temp epoxy around it. Noce job. Cost $30
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Glad you got it fixed.
    If you ever need to replace it.
    B&M makes a stacked plate cooler Exactly like the stock one except it has 1/2 inch NPT threads. You can get adapters from most Hyd hose shops To hook everything up.
    Its called The super cooler. I bought mine from Summit 59.00
  10. 88Silverado
    Mar 13, 2003
    2,664
    Thanks Thunder!
    I will keep that in mind if it leaks again /forums/images/graemlins/thumb.gif
