88 rearend
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, May 10, 2003.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    One of my buddies has an 86 k5 and the rearend is gone. It is all stock ,but has found a rearend out of an 88 k5 will it fit in I called some junkyard and he said no ,but I don't see the difference.
  2. 85army tank
    85army tank 1/2 ton status
    Sep 25, 2002
    276
    southren mn
    /forums/images/graemlins/k5.gifthere should be no difference in them just make sure it has the same gear ratio as the front diff i have an 85 and an 88 and they are both the same hope this helps plus the junk yard is prob thinking it is from a pick up and if that is true then i dont think it will be a bolt in but if it is from a 88 blazer it will /forums/images/graemlins/k5.gif
  3. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Yeah it will fit, junkyard might have got confused with a 88 pickup? don't know if they're different.
