88 SILVERADO DRIVETRAIN
Discussion in '1992-Present Chevy & GMC models' started by COOTER, Sep 27, 2001.
  1. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    I WAS CHANGING MY OIL TODAY . I TURNED MY FRONT DRIVESHAFT TO CLEAN THE OIL OFF FROM THE FILTER IT SOUNDED LIKE ONE OF THOSE OLD BICYCLE BELLS RINGING ? IS IT SUPOSED TO SOUND LIKE THAT?
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    uhh, no.
    Is it loud?
    Poundin' the ol "pavment"!
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Unless you ran over your kids bike and the bells jammed in there...NO! Disconnect the driveshaft from the t-case (and not the diff) and spin it, if it makes noise it's in the frontend (diff, axles, hubs, etc) try it with and w/o the hubs locked. Then turn the t-case end in the different ranges. If its quiet on both sides, it's probably the driveshaft. It will take some time, but process of elimination is what it will probably boil down to. Let us know what you find.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  4. COOTER
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    ITS THE FRONT DIFFERENTIAL.NOW WHAT?
  5. RedDwarf
    May 9, 2001
    816
    Now take it to a shop and bend over [​IMG]
    Still Poundin' "pavment" after all these years!!! [​IMG]
  6. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Pull the diff cover and take a look see.. Maybe it just needs oil? Probably should get it fixed but I'd probably run it till it grenades and put 3/4 ton gear under my truck.
  7. COOTER
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    THANKS FOR THE ADVICE BUT I DONT TAKE ANYTHING TO A SHOP UNTIL I GET DONE MESSIN IT ALL UP TRYIN TO FIX IT MYSELF.
  8. RedDwarf
    May 9, 2001
    816
    It doesn't have a diff cover. The diff housing splits in half from front to back. It must be removed from the vehicle to do this.
    Sounds like it needs more than oil.
