88 suburban 3/4 ton lift/tire questions
Discussion in 'The Garage' started by gar, Mar 6, 2005.
  1. gar
    gar Registered Member
    Mar 3, 2005
    10
    Concord, CA
    hi all -- just purchased a 3/4 ton 88 'burban.
    So my first question is what's the maximum tire size that I can run stock (WITH trimming as necessary)? Would 35"'s fiit? Larger even? Ideally, I'd be running a more narrow tire, nothing too wide.
    Thanks!!!
    -Garrett
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    255/85R16 (33") fit my crewcab without any lift or trimming. I bet you could jam a Q78 Swamper, or a 9.00R16 Michelin on there with a little trimming. ;)
  3. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Congrat's! As far as tire size, the actual height vs. listed size / height vary among manufacturers. I'd try 33's, 35's. Measure the actual tire on a friends truck. As for trimming...that's the spirit we love here!!:D
    I've used sawzalls, but now prefer using a cutoff wheel. 4" wheel for cutting steel works great.
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    the tire sizes go way up when you are willing to shed some sheet metal... i know theres couple of guys on here with 6 inch lifts running 44's.
  5. gar
    Mar 3, 2005
    10
    Concord, CA
    so far, I like what I'm hearing -- so my next question is, should I stick with 16.5" wheels, or can I drop down to 16" or 15" (remember that this is a 3/4 ton truck)? If I do stick with 16.5", anyone have any experience with the H1 wheels with beadlocks/runflat inserts?
  6. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I ran 35 bfgs with 3" body lift and it rubbed....alot .with 5" lift (3 body 2 addaleaf) 0 rub ,now as for the 39.5s I had to cut some metal but its still just 5"lift
  7. gar
    Mar 3, 2005
    10
    Concord, CA
    but when you had the 35's and it rubbed, that was without cutting, yes?
    -Garrett
  8. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    When I got my 90 burb it was bone stock. The first thing I did was buy 33x12.5x16.5 wild country mts on 16.5x9.75 wheels. I had to trim the fenders to keep it from rubbing. You could probably get away with a add-a-leaf for the the front.
  9. gar
    Mar 3, 2005
    10
    Concord, CA
    Well, I figured that the 33"'s would work, as a friend's blazer has 33's at stock ride height.
    Is there any reason you went with the 16.5" wheel? Could I actually use either a 15 or 16 inch rim, or are those impossible to find in 8 lug?
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    Since you said you liked skinny tires.... the Q78 Swamper comes in both 15" and 16". The Michelins are 16" or 20". 15" wheels seem to have the widest selection of tires though.
  11. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    My truck started out as a 3/4 ton so the 16.5 were an easy find.
    With the 15" you will have to grind the front calipers a little and the 16" are actually factory wheels.
  12. gar
    Mar 3, 2005
    10
    Concord, CA
    ahh! Mystery solved.
    So generally, would it be correct to say that 16" is a better wheel to go with due to the ability to hold a bead better than a 16.5? Is there any advantage to be had by going to a 16.5" wheel over the 16, or is it purely an issue of what's available in 8 lug?
  13. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    Well the 16" used to be hard to find because the mfg. did not offer many wheels in that size. Now all the companies are building them. It seems like the 16.5 are now becoming extinct as most companies are going to 17's and bigger:mad:
  14. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    rim choice.
    15 inch rims would rub the calipers i believe on the front.back would be fine.16 inch rims are found pretty cheap if you get steal wheels.i got mine for 40 apiece.if you are going to get tires anyway,you can get a package with rims for cheaper than buying them separate.i have 16.5 inch rims and havnt had the problems that people say with them losing a bead when aired down.if you are affraid of that go with a 16 inch rim.the bead is a 90 degree the same as a 15 inch rim.as for tires you could go woth 35's and trim some fender.ithink even with 33's it will rub a little when fully stuffed.4 inch lift is pretty cheap.or you could do add a leaves.good luck and congrats on the new ride.
  15. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i have 2" adda leafs from tuff country if you want them. they are brand new, never been on a truck, i completly am going about lifting my truck a different way now so i dont need them
  16. gar
    Mar 3, 2005
    10
    Concord, CA
    the add-a-leafs sound cool, but given that you're in SoCal, the cost of gas would probably exceed the cost of the leafs! :)
    Anyways, if I did decide to go with 35's, would they fit on the 'burban well enough to where I could drive on the street until I was able to get the fenders trimmed up? Just trying to avoid purchasing another set of wheels.
    -G
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Those for the rear. If so, PM me.
