88' TBI 350 - Need suggestion on a Camshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jbissette, Nov 5, 2001.
  1. jbissette
    jbissette 1/2 ton status
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    88\' TBI 350 - Need suggestion on a Camshaft
    I have an 88' TBI 350 and I need advise on a good computer compatible camshaft.
    88 Chevy K1500, 350 TBI, TH700R4, 3" body lift, 33x12.50x15 Tires
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Re: 88\' TBI 350 - Need suggestion on a Camshaft
    call whatever company you decide to go with. cams and tbi needs to be matched extremly well to the type of driving because it relies on absolute manifold pressure readings to run right. comp cams, crane, etc. should be able to help you find the best cam for you. wouldn't hurt to comparision shop either.
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Most things I've read is, keep duration reasonable, and keep the lobe seperation at 112 or above. Just so you know, if you were thinking Comp Xtreme 4x4--it's ground on a 111 lsa.
    Tim
