88' tbi ...do I have to use the serpentine system or AIR pump stuff?
Discussion in 'The Garage' started by juanblzer, May 9, 2003.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    88\' tbi ...do I have to use the serpentine system or AIR pump stuff?
    I /forums/images/graemlins/grin.gif just removed the tbi,harness,fuellines,manifolds etc. from my donor 88'gmc1500. Do I have to use the serpentine system? What about the airpump system. It seems that the previous owner capped the part that goes into the passenger exhaust manifold port? Do any sensors tie into the serpentine system and do any sensors tie into the AIR/smog pump? Thanks in advance.
    juan
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Re: 88\' tbi ...do I have to use the serpentine system or AIR pump stuff?
    No you do not have to use the serp. setup, but depending on your location you may fail a visual inspection for emissions equipment.
    You do not have any sensors and such that will mess up without the serp setup.
    John
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Being that you are retrofitting it into your Blazer, if the Blazer didn't have an air pump you should be able to get away with it. Not legal to the exact letter of the law, but most "inspectors" won't even notice. I would, however, get exhaust manifolds without provisions for the pipes. Not completely necessary, but that would be a visual tip-off for them (don't give them any ammo to use against you). Your serpentine is not necessary. If you go with a V-belt setup you will need to change your water pump and fan to a std rotation instead of reverse rotation like the serpentine setup uses. No sensors tie into the use of the serpentine setup, and the only plug you may have left over when you finish is the diverter valve actuator harness (two wire connector). I've run vehicles that had them without hooking them up without problems, so you should be ok. If you're not going to use the serpentine setup, I may know someone interested in taking it off you hands. PM me if you're going to get rid of it.
    God luck,
    Nick
  4. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Juan
    Give me a call if you want to do some wiring on Saturday.
    Mark
  5. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    I bought an 88 K5 to swap the motor into my 70 k5. I dont think mine had the sepentine setup. Is it different for the Blazers then the PUs?
