88 tbi running rich
Discussion in 'The Garage' started by ron88k5, Feb 10, 2004.
  1. ron88k5
    ron88k5 Registered Member
    Jan 13, 2004
    31
    pioneer ca
    my 88 k5 350 tbi is running real rich i've done a tuneup changed the o2 sensor ran codes did'nt have any i was thinking cat was bad but i dont know any ideas /forums/images/graemlins/confused.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Hook up a fuel pressure gauge and see how high you FP is with the truck running. PS...how do you know it is running rich?
    Chris
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Did you get a code 45 ?
    Besides changing O2 my book says check charcoal canister and fuel pressure regulator vacuum line for gas.
    Mine just went the other way, got a lean code, fuel filter was plugged.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You may need to disconnect the battery cable for 5 minutes or so to reset the ECM. Reconnect it. Run the vehicle. Then scan for codes. If you are running way rich you should be throwing some codes.Usually 45. The ECM may be in bypass mode and may not throw codes untill reset.
    Among many other things. A bad coolant temp sensor can cause a rich condition.
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    You really only need to remove power for 25-30 seconds. If you're lazy like me you can just remove the ECM fuse for the same amount of time, then you don't have to reset your radio. /forums/images/graemlins/grin.gif
