88 toyota pickup, taillights and license plate light dont work,
Discussion in 'Other Rides' started by R72K5, Jul 31, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what could be wrong ? what to check on toyota pickups ? i know zero about them
    thanks for anything
  2. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    you check the fuses and the bulbs themselves?
  3. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Check the wiring harness on the drivers side, right under the tailight. Also check the fuse, and make sure the plate lights are grounded.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    problme was the yellow connector on top of pass side rocker under the carpet under end of the bench seat there
    ti was corroded pins and dirty, had to spray it and mess with it,
    all is good nowo,
    but fuel guage it doesnt work its below empty all the time never moves, never has no matter how much fuel is in it, ive filled it to overfull spilling out and it doesnt even glitch at all
    dead, i tried the plugs after pulling bed off and everything,
    the float arm is moving around in there you can hear it bobbing around if you shake the truck at night when its really quiet out
    so float is fine and arm, too
    im lost,.,
    thanks for anything, opinions, ideas on that one
