88-up Pickup T-case fit a 73-91 K5?
Discussion in 'The Garage' started by plowboy77, Oct 2, 2006.
  1. plowboy77
    plowboy77 Registered Member
    Mar 18, 2006
    9
    Eastern Kansas
    I know a lot of people do solid axle conversions on the 88-up pickups but wasn't sure what they did about a transfer case...do they mate up a passenger side drop case, mount a divorced case, or if they used a Ford :eek1: front axle?
    If they mate up a passenger side drop case, I was wondering if it would work in reverse. If a transfer case from a 88-up pickup (92-up blazer) with the driver's side front output would bolt up to a 1980's-1991 K5 transmission?
    Mixin' and matchin'
    Thanks!
    R
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    With the IFS to SFA swap , many use drivers drop axles and the existing case .
    For a pass side case , a np208 , or np241 would bolt to the IFS trucks tranny . As both had the round 6 bolt pattern .
    However I do not know whats in the way , or what you need to cut to run a pass drop case . Maybe exhaust rework too .
    Seems simpler to us the existing case , and a evil Ford front d44 or d60 .
  3. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,790
    99
    Paducah, KY
    Evil? The Ford Danas are reverse cut high pinion axles...superior strength to the GM equivalents.
    I looked into this with my '92 Blazer K1500 and had both options. I eventually started down the road towards the Ford D44 because it was simpler. To use the SFA t-case I'd have had to reroute the exhaust, rework at least one crossmember, and generally deal with stuff that I wouldn't have had to otherwise.
