89 3/4 surburban help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigreid, Apr 1, 2002.
  1. bigreid
    bigreid Registered Member
    Mar 8, 2002
    21
    Anchorage, Alaska
    I need help from the experts! I am looking at an 89 3/4 this afternoon. Do all of those have the 400 series trans or do some have the 700R4? I want an 89, 90 or 91, is one year better than the other? Do all 3/4 tons have the tow package and all of the oil coolers? If they don't what do I look for to see if it does? If there is any other info that you think is important please let me know! Thanks for all your help>
    Adam
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    89 and 90 had th400s, 91 had either a th400 or a 4l80E. You really want a 4l80E, its basically a th400 with an OD.
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    <chanting> 91, 91, 91, 91, 91, 91....
    ...but, of course, I have a biased opinion /forums/images/icons/smile.gif.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep, that was what I was going to say. If at all possible find a 91 3/4 ton Sub with an Auto with OD. It is a 4L80E mated to a NP 205 if I remember right. From what I understand it was the only year that combo was offered, and it is a very desireable combo. Any year 3/4 ton Sub is good, but 91 is about the best.
  5. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Actually, a '91 Sub 3/4T w/ OD is a 4L80E mated to a NP241 case...
  6. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    <echoing the chant> 91, 91, 91, 91.....
    While mine is only 1/2 ton, i'm trying to put 3/4 under/in/around it every chance I get!
  7. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    yeah, an 89 would have a th400 and np241. The last year for the 205 was 1980.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What case did the 1 ton's have in 91? Maybe it was the 91 one tons with the 205. There was something special about the 91 something where it had a 4l80e backed by a good case. At least I thought so.
  9. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    1991 V30s had the 4L80E/NP205 setup.
    My '88 V20 suburban has a TH400/NP208.
    Just bought a NP241 'case from a 1990 suburban that had a Th400 and uses the electronic VSS instead of the mechanical speedo.
  10. MudbogAD
    Jun 29, 2001
    672
    That's awesome if they put a 205 in those in 91. That's a strong combo. I thought they stopped in 80, but maybe thats only for the half tons. Yeah 1980 was the last year for 205's in jimmys and blazers.
  11. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Not sure about the 1 tons having a 205...
    Since I have a '91 V2500, it's definitely NOT a 205. Now you've got me curious! Time for my favorite search engine to engage...
  12. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    I'm possitive about the '205 in the '91.
    I ran across a 1991 V3500 crew cab dually 4x4 at the junk yard. It had a 6.2/4L80E/NP205 in it.
    Only thing wrong was the trans was bad. I tried to buy it, even left my name and #, but not for sale. It was some old guy who knew an employee at the yard. Truck had sat for 2 yrs with bad trans and he still wouldn't sell.
  13. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    There you go...answers that question.
    3/4 & 1/2 tons DO NOT...
  14. OldBlew
    OldBlew Registered Member
    Mar 10, 2002
    28
    Girdwood, Alaska
    Yep, you are right.
    I've got a 4L80 + NP 208.
    A 205 with lower gears would be nice!!
  15. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Your 208 case must not be original...should be a 241C. A 208 case in a '91 would require a retrofit.
    The 208 used a cable for the speedometer, whereas the 241C uses a VSS at the case. '90-'91 is a VSS at the case and an electronic speedo. '87-'89 used a VSS also, but it was in the dash cluster.
