89' 454 Smog Pump Delete Pulley?
Discussion in 'The Garage' started by AZ_Overdrive, Jun 8, 2006.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    Anyone know what GM part number can be used to replace the smog pump on a serp setup with an idler pulley on a 454?
    Thanks,
  2. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Care to share the answer with this board?;)
  4. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool how much was that? What did you do with all the lines to/from the pump and the manifolds.
  6. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
    Cost was about $40 from gmpartsdirect. Since I have not put the 454 in the Burb yet it was simple to remove the smog lines. I took off the tubes on the manifolds and the one around the back of the motor. My accessory brackets are off the motor now since I am having the motor rebuilt soon but I plan on just taking off the pump and it's plumbing. The folks on 454ss are saying that you can disconnect the wire harness from the pump and it won't hurt anything ECM wise.
    I have posted before but here is the website to my swap (in early stages):http://www.team-lan.com/454swap.html Guess I should put that in my sig.
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool man thanks:wink1:
