89,90,91 owners with 4" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, May 9, 2002.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    89,90,91 owners with 4\" lift
    is there an issue with my driveline length? i put a superlift 4" on about a year ago, and it seems that ever since then, i hear a jangly kinda noise when i deccelerate, or at nuetral throttle.
    i thought it was the R&P going out, but i just put in a complete 12b, and the noise is still there.
    any guesses?
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Re: 89,90,91 owners with 4\" lift
    Did you drop your t case at all? Mine does the same thing but I have my case dropped.
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    "jangly" does that sound like a pipe being dragged on the road? Cause I get the same exact sound when coasting and decelerating. I'll follow this post to see what other people say. I have an 85 on a 6" lift with an extened driveshaft. The guy that built my DS said its vibration in the shaft. I tried to shim my rear axle to improve the angle but the noise is still there.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i have an 89 3/4 ton suburban with a 4" and i don't get any jangly sound. i wouldn't be able to hear it over the TSLs anyway.
  5. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    try dropping the t-cass, i used to get that noise type af deal and when i droppeped my t-case i went away,l and then i blew up the carries in my ten bolt, swapped in a 1-ton 14 bold and i've never heard that noise again. also when you drop the t-case you might have to have a new peice lowered on the x-over pipe on your exhaust. btw mine is a 91
  6. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    I have an 89 Jimmy with 6 inch lift and T case dropped 1 inch, before installing a cv driveshaft from Arizona driveline I had this exact same problem.
  7. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I sure do... I always thought it was my rear end because I did my lift and axles at the same time. But I had kinda wondered if it was the tcase or something... I dropped my tcase using the factory spacers and I also have an extended driveshaft. If you find out what it is please be sure to tell me as it's very very annoying.
    Since I do have an extended dshaft though I'm thinking about raising my tcase back up and seeing if it still does it.
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i hear that sometimes too but i dont think its the t-case. when i first lifted the truck i dropped it just to see the diff. but like someone said it will put your front drive shaft on the exhast pipe crossover (unless your exhast it modified) so after a couple months i put it back up and have still heard the sound. its a 89 with 4"s
  9. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    I have the same problem with my 84, and it started the day I added my 4 inch lift. I have since lengthen the driveshaft, and it still does it. I refuse to lower my t-case because I don't want to lose any ground clearence. I have heard before that a slip yoke elimenator kit will solve this problem because it is something to do with the slip yoke, but I have an np-208 and there is no kit made for mine, your 91 on the other hand since it has a different t-case can get a slip yoke kit. If it makes you feel any better though, I drive 60 miles a day on the freeway at around 80mph for about two years now, and I have never had anything go wrong or break, I simply apply the brake a little bit before I let off the gas and the noise goes away.
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Wow... up around 65 mine gets to where the whole blazer just shakes and the noise is really bad. I can't imagine doing 80 like that.
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I don't think that the longer driveshaft will make much difference. It sounds to me like we are all in need of c/v shafts. That noise and vibration comes from the bad operating angles of the u-joints in the shaft associated with taller suspension. Dropping the case helps, shimming the rear end up helps, but only a c/v shaft will completely eliminate it. Mine does the same thing between 65-80mph but any faster or slower it doesn't do it. Just my $.02
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    lol, I have an interestin perspective on this. I have a '76, 4 inch rRancho, and t-case dropped an inch. Mine makes the exact sound ya'all are describing, BUT it didn't do it till after I drooped the t-case. LOL, But I know what it is. On mine it's the e-brake cable clanging on the tail housing of the t-case. Only when decelerating and while idling. If I depress the e-brake a couple clicks, it stops. Try that and see what happens. It took me aloooooong time to figure that one out. Good luck. /forums/images/icons/smile.gif
