89-91 conversion complete
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dale_gribble, Dec 31, 2006.
  1. dale_gribble
    dale_gribble Registered Member
    Sep 20, 2006
    90
    Utah
    I just finished installing my 91 suburban grille conversion on my 88. It was a pretty long process; I logged about 10 hours doing the whole conversion by myself. I used the original wiring harness and spliced in the 91 pigtails- I soldered the splices, used heat shrink tubing and then electrical taped them; they SHOULD hold up well. Since I had to pull the radiator and had the core support available, I installed a B&M tranny cooler as well and changed the tranny fluid/filter.
    I was less then impressed with the taiwanese repro grille and headlight bucket crap. As a matter of fact, I was pretty disgusted. I had to dremel quite a bit around the grille to even get a decent fit, and the buckets and grille don't line up very well. At first I thought it was just how it was stock, but when I test fit the original trashed GM pieces, they went together a lot better. I would have to recommend to anyone wanting to do this to go OEM grille and buckets, even if it's used.
    Here it is! I could SURE use the grille emblem if anyone has one lying around. Please PM me; I will buy it from LMC truck otherwise.
  2. dale_gribble
    Sep 20, 2006
    90
    Utah
    My next project-
    And then the Doug Thorley headers and I am calling it quits for a while... By the way, I have been working with Doug Thorley's tech support, they are amazing. I sent them some pictures of the engine compartment, their R&D team looked at my setup and gave their recommendation within an hour. They have a special on the headers and y-pipe right now for $450 directly from Thorley. On the system I ordered, the y-pipe is even made for a 4-6" lifted truck! The tech's name is Sean Crary. Awesome guy! Those Thorley header's are 14ga steel! and have 3/8" flanges! Those are the sturdiest ones out there.
    Sean mentioned on a stock TBI motor to expect 20 lb/ft at 2100 RPM with a slightly faster torque delivery as well. I heard the tri-Ys are good for torque and good balance of a short and long tube design.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Truck looks so natural, looks great. Thanks for warnings on Taiwan stuff. I installed an LMC grille and HL rings; they're good enough, fit, and the right price.
    Thats one outsatnding rig you're building!:bow:
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That looks great.
  5. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Your rig is so sweet! Nice upgrade with that front clip. Looks clean
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Nice job!
  7. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    what size lift and tires are you running? i just picked up a 91 burban with 6 inch lift and 36 inch swampers
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    pics????
  9. dale_gribble
    Sep 20, 2006
    90
    Utah
    37x12.50" BFG A/Ts on 17x10" MB Gunner 6's with a 6" BDS suspension. I don't have a single rub issue anywhere in travel or turning.
  10. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    Let me know if the OEM emblem fits in that grille. The aftermarket grilles I looked at were like yours with only the square recess not the oem bowtie shape so my emblem wouldn't fit in them. I ended up using the used grille I picked up for that reason.
  11. dale_gribble
    Sep 20, 2006
    90
    Utah
    Just for you, I took a few pics; The reman grille obviously doesn't have the inlet for the emblem, however the emblem still looks pretty good and goes over the square recess ok. I did have to dremel the square recess; it was too high and was holding the emblem away from the grille. I took a few pics to document-
    Pic of emblem over square recess pre-dremel; Note the gap between the emblem and grille. Not too fancy...
    This is the square recess post dremel-
    The grille with the emblem being held in place while RTV drys; nice and snug fit-
  12. smalltowncowboy
    Jan 16, 2006
    503
    hermiston oregon
    here is my 91 6 inch lift and 36 inch swampers
  13. dale_gribble
    Sep 20, 2006
    90
    Utah
    Nice burb! God I love burbs...
    You could probably pick up 1-2mpg and a few cool points just by deep sixing that old bug guard... :D
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah but do you have any idea how usefull that thing is?
    I never knew until I ditched mine. :eek1:
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I'm thinking about putting one on myself. Might have saved my new H3 from a stone chip, just off my 80 mph line of sight.:doah:
  16. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    true, but it looks so much better w/o it:bow:
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You wanna see how ugly mine looks now without it?
    It has chips and cracks all over the windshield, and the bugs are so hard to clean.
    :mad:
  18. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Good looking burb.
  19. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    Thanks for the pics
  20. smalltowncowboy
    Jan 16, 2006
    503
    hermiston oregon
    i just picked up the burban last thursday, so i havnt had a chance to do much of anything. im going to be getting rid of the 36 inch swampers. i will either be going with some 35 inch BFG M/T, or if i get my dana 60 i have some 38 inch swampers ill run.
