89-91 GUYS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Dec 30, 2000.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    When you flip on your brights, do all four head lights come on or just the center two? On low beams, my outer two are on and on high beam only the inner two are on. Are all four supose to be on, on high beam? TIA
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
  3. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    That is the way it is supposed to do. Mine does the same thing. There is a wiring kit you can buy that lets all 4 lights stay when the high beams are on. Here are two that i found in the Summit catalog. Hope this helps.
    Summit makes one part # SUM-G6219 $14.99
    Painless Performance part # PRF-30802 $20.95
    <A target="_blank" HREF=http://k5junkie.coloradok5.com/>http://k5junkie.coloradok5.com/</A>
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    The outer bulbs have three terminals. Why couldn't you just jump a wire over from the high side of the outer bulb to the inner bulb? Would it be too much for the exsiting system to run all four lights?
    Not FROM the people
  5. undertow
    undertow Registered Member
    Dec 14, 2000
    60
    Southern California (San Fernado Valley)
    is there a kit like that for late model chevys?
