89-91 rear seatbelts??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BulldogK5, Oct 14, 2002.
  1. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I ran a check & came up empty. My 91 has the shoulder belts bolted to the top. One side is missing bolts but I was wondering what anyone does for restaints when you remove this style top. /forums/images/graemlins/k5.gif
  2. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    the 91 is the only one with the shoulder belts in the rear... if you are talking about the rear.
  3. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    Yup I have a 91 and mine are overhead...is there a quick release on them to disconnect them for cap removal? I havent had a chance to look
  4. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    The spring mechanism that hold the top of the belt is bolted to the cap with 2 bolts. I could not find a way to mount the box anywhere else once the cap was off, so i ended up cutting mine and turning them into permanent lap belts. /forums/images/graemlins/smirk.gif Probably not the best idea, but it works.
  5. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i just pulled the bout fron the floor, so that i could put it back in.
  6. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I just unbolt mine from the top. Two bolts per side and they are down. As for the passengers in the back I've only had more than two people with me 3 times and never with the top off. If it's just one person I tell them to sit in the middle where the belt is. I've thought about getting some lapbelts but that's money I'd rather spend somewhere else /forums/images/graemlins/smirk.gif.
  7. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    I have a 90 Jimmy and they are bolted to the top /forums/images/graemlins/eek.gif So I just unbolted them from the floor. At the time they were striped out so I had a nut welded on them and finally got them out with an impact wrench. /forums/images/graemlins/thumb.gif
  8. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Mine is a '90 and had those too. I bought 2 lap belts from Checker Auto and put those in. The floor bolts were very hard to get out and required some heat, but it didn't take too long.
