89 Blazer front drive shaft
Discussion in 'The Garage' started by Thunderrug, Jan 23, 2006.
  1. Thunderrug
    Thunderrug Newbie
    Dec 8, 2005
    3
    Ontario Canada
    I have an 89 chevy k series 1/2 ton gasser and my front drive shaft is fricked and I am looking for a replacement.
    My question is are there any differences to a mid 80's pickup or are they all the same. If not what ones will fit?
    Thanks and all you guys are a great source of info keep up the good work.
    Thunder.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they should be the same.
    welcome
  3. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    probibly needs to be from a pickup with a np 241 transfer case, like your 89 blazer uses. don't know for sure, but if i was you i'd check.
  4. Thunderrug
    Thunderrug Newbie
    Dec 8, 2005
    3
    Ontario Canada
    How do I know what transfer case it is? Kind of a newbie so bear with me.
  5. bernman
    bernman Registered Member
    Oct 4, 2005
    26
    ny
    you have a np208 t-case, not the np241 you will be able to find many shafts to fit, but try to find the ones with the coarse- splined slip and stub. the fine spline will usually spin under high load
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    89 blazers have 241 t-case. you can use a driveshaft from a truck with a 208 or 241, both use the same driveshafts.
  7. Thunderrug
    Thunderrug Newbie
    Dec 8, 2005
    3
    Ontario Canada
    Thanks to all your replies.
