89 Blazer K5 Balljoint Replacement
Discussion in 'The Garage' started by FrontMed, May 24, 2005.
  1. FrontMed
    FrontMed Newbie
    May 24, 2005
    Hot Springs, AR
    My son (who is highly mechanically inclined but awfully impatient at times) has undertaken to replace the ball joints on his '89 blazer -- a project which neither he nor I knows the first thing about.
    So far, it isn't going well. He has pounded on the top spindle of the ball joint ad nausem without it so much as moving. He purchased a tool (a "fork") that was supposed to help get it out, but still, no joy.
    Is there some tried and true method for doing this that he is overlooking, or is this the reason they charge an arm and leg for doing this?
    TIA for any suggestions.
  2. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    There is a large c-clap looking tool that makes it very easy for ball joints and ujoints. You will need a special socket to intsall the upper ball joint sleeve. I got mine from snap on, if you search you can find a part number.
    http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2004148/showCustom-0/p-2004148/N-111+10201+600003587/c-10101
    It was a good investment for me anyway I have used it countless times on ball joints, ujoints, compressing leaf springs, installing/removeing leaf spring bushings and a number of other things.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    As for the special socket for the adjustor: Parts Mike has the best price i have seen http://www.partsmikeparts.com/ball_joint_adjuster_tool.htm, or your can make your own with a grinder and a $5 socket from somewhere like HF
    for the press tool, you can rent them from autozone ($99 +tax) and then get the full refund when you return it (you keep it as long as you want), they also come in handy when you're changing Ujoints (may want consider doing the front ujoints while you have everything torn apart now, 3 out of 4 times they need the service)
  5. FrontMed
    FrontMed Newbie
    May 24, 2005
    Hot Springs, AR
    Thanks everyone for these replies.
    He's on his way to autozone now (if he can rent it, that's good -- I have a feeling he may not be doing this again ...) LOL.
    Thanks, again...
    FM
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Have him take a look at this ball joint write-up.
    And as mentioned before the special socket for the sleeve for the upper ball joint can be made out of a 13/16 deep socket.
