'89 blazer pings on part throttle acceleration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by etr, Dec 2, 2002.
  1. etr
    etr Registered Member
    Oct 20, 2002
    5
    San Mateo, CA
    \'89 blazer pings on part throttle acceleration
    Hey all,
    I'm really liking my newly purchased '89 Blazer. Way better than one of them sissy import SUVs. ;-) But, it has a minor problem. Driving on a flat road at say 60 mph, it'll ping a little when I give just a little more throttle. Hills do the same thing. Down shifting out of OD reduces the ping. Engine has 150k, new plugs and rotor. I'm using 87 octane fuel. Running 31x10.5x15s with 3.43 diff ratio. stock tranny. More throttle stops the pinging. Otherwise runs great! I'm thinking manifold leak of some kind, or carbon deposits. Anyone had something similar or know of a common cause for this problem? Or am I due for a lengthy trouble-shooting session?
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Re: \'89 blazer pings on part throttle acceleration
    Check your EGR valve, also check the knock sensor & conector. Make sure vacuum line are all good too /forums/images/graemlins/thumb.gif
    Jim
  3. unsane
    unsane Guest
    too much timing advance?
  4. Re: \'89 blazer pings on part throttle acceleration
    The timing on an 89 is computer controlled. I'll second the knock sensor.
  5. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    try the gas run a higher octane it'll slow the burn of the fuel and reduce the pinging ummm i think /forums/images/graemlins/grin.gif
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I was getting a ping when my intake was leaking.
  7. dyeager535
    26,979
    It might get rid of the pinging, but it would be covering up a problem, not fixing it. $.10/gallon more ends up costing a fair amount of money on these trucks /forums/images/graemlins/smile.gif
  8. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Replace the Knock sensor. Mine was disconnected and pluging it up didn't help. Finally replacing the knock sensor fixed it.
  9. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Check knock-sensor. You can "ask" the computer if there are any codes. It should tell you if it is getting a reading from the knock sensor.
    Could also be dirty injectors and/or carbon buildup on the pistons. Try running two tankfuls of Chevron 89 or 91 octane through it. Don't run cheap-o gas. I keep finding water in Arco gas - and sometimes my fuel-pumps would rust out!
    Good luck.
  10. etr
    Oct 20, 2002
    5
    San Mateo, CA
    Thanks all for your input. I'll try these suggestions out and let you all know what happens.
