89 Blazer Silverado - Electrical Problem
Discussion in 'The Garage' started by CircuitMan, Aug 15, 2005.
  1. CircuitMan
    CircuitMan Newbie
    Aug 15, 2005
    3
    denver
    Hi, I'm Kyle, I'm an installer for Circuit City, and I joined this forum to ask about an 89 Blazer I want to buy. He is flexible on the price because the truck has developed an electrical problem - it starts, but any bump causes it to die - and the ecm fuse blows. Is the ecm shot? Has anyone heard of this problem? And were would I start to look for the problem? How complicated is the ecm on this vehicle?
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
  3. CircuitMan
    CircuitMan Newbie
    Aug 15, 2005
    3
    denver
    wow, I read those topics, and it sounds like a ton of work to troubleshoot this problem. I have a couple questions - Ehat does and ECM cost? and How much time and money should I expect to spend on this sort of a problem?
  4. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I had a problem similarly to this on my 90 K-5. It turned out that one of the wires that the ECM uses had shorted out. Once I found it it was an easy fix. I know that this wont help you find your problem but it’s a short somewhere in your wiring harness.
    Dan..
  5. dyeager535
    26,979
    Don't waste money on the ECM, 99% of the time they aren't the problem. Agree with the others, likely a wire issue before it gets to the ECM.
  6. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    Circuitman, you wouldn't happen to install car alarms would you?
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Gonna have to trace a wire, cause you have a short...
    My S10 Blazer did that. Found that the PO had put spade connectors on the oil pressure switch instead of a new plug, and after a long trip, the exhaust heat melted them together and would blow the ECM fuse.
  8. CircuitMan
    CircuitMan Newbie
    Aug 15, 2005
    3
    denver
    yes, 6.2LTrailblazer84, I do ;-) So then, how much time should I plan on to fix this, if it takes a long time? I'm feeling like I'd better get this truck cheap - there are a lot of blazers out there.
