89 blazer suspension kits
Discussion in 'The Garage' started by 89 k5 blazer, Jan 26, 2003.
  1. 89 k5 blazer
    89 k5 blazer Registered Member
    Jan 21, 2003
    13
    Rockville, MD
    I've seen alot of suspension kits for blazers years 87 and below. are these kits compatable with the 89. /forums/images/graemlins/k5.gif
  2. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Yes they are /forums/images/graemlins/thumb.gif
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Almost every lift system I have seen has seperate listings for the 88- 91 Blazers and Subs. I'm not sure what the diference is. But I know that the frames are diferent in the front on the 88 and up than the eariler models.
    Just to be safe I think I would order one for your year.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    K5's take the same springs from 1973 through 1991. /forums/images/graemlins/cool.gif If you notice, most listings lump 73-87 K5's, 1/2-ton Subs, and 1/2-ton pickups into the same category. However, the pickup trucks totally changed in 1988 and take a completely different lift kit. 88-91 K5's and Subs take the same lift kit as previous years, unless you want lifted rear springs. In that case, the Subs have longer rear leafs, so they take a different rear spring than the K5's. /forums/images/graemlins/thumb.gif
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The only difference in the kits is the size of the rear bolt that goes into the shackle. My kit ended up giving me the wrong size bushing insert, so I had to search for a different bushing insert so my larger stock bolt would fit. You may have to go throught that...
