'89 Burb with a vibration @ >60MPH
Discussion in '1936-Present Suburban' started by KRAZIE87K5, Aug 1, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    \'89 Burb with a vibration @ >60MPH
    There is a vibration in my Burb that is overwhelming @ 70mph on the highway. I can tolerate it at 65mph... which is my max speed unless I have room to crank it up past 80mph where the virbration lessens. The u-joints seem to be tight to me in the rear drive shaft... so I am looking for suggestions. Bueller? /forums/images/graemlins/burb.gif
    -Dan
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: \'89 Burb with a vibration @ >60MPH
    My first guesses would be u-joints and bearings?
  3. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    maybe you could load it up with women and charge for pleasurable rides to make some extra cash and if it goes well I could drive it from 9:00 am to 3:00 pm lmao /forums/images/graemlins/rotfl.gif
  4. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    sounds to me like an out of balance tire, or seperated tread belt. funny how we miss the simplest things on the most complex machines... my C20 did that, and all I did was swap on different tires, and it runs smooth as glass again. another higher end option could be your transmission mount is broken, and the transmission is no longer in a strait line with the rear end. this happened on the C20, and cost me a transmission before I found the problem. of course, if this is a 4x4, the transmission mount should actually be the transfercase mounts...
    good luck with it,
    -Ddragggon
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Check you're tires for proper balancing first. Make sure they haven't lost any wheel weights. Also, check your driveshaft for damage from rocks, etc. You can also find someone with the same truck as you and try their tires and driveshaft to see if that helps.
  6. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    had the samething in my 85 (girlfriend loved it)
    put in new u-joints and fixed it,tires were checked and fine.
    factory u-joint 144k miles and not a bearing left in it.
    goodluck
  7. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    Don't discount the possibility of a warped or cracked flexplate. I replaced just about everything before I finally solved my vibration. Still, check mounts, U-joints, shocks, tires, rims, bearings, ignition, and so on, but take a few seconds to pull the dust cover and check your flexplate for runout. You may be surprised...
    See here for how I solved my problem: 1986 Chevy Suburban C10 Silverado 350/700R4 flexplate replacement
    Good luck!
    Kevin
    /forums/images/graemlins/usaflag.gif
  8. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    U-joints, tire balancing, drivshaft. If none of that is the problem I would checks your wheel bearings and axle shafts on your rear end. Thats what mine was. I toasted bearing and axle shaft on a 12 bolt. Might also want to check your tranny/transfer case mounts. Good luck.
  9. Re: \'89 Burb with a vibration @ >60MPH
    tranny mount, engine mounts, t-case mounts, u-joints, wheel bearings, tie rod ends, drag link ends !! I had a bad tranny mount that gave me a lot of vibes once on the ole Burb! Make sure you check the u-joints and rod ends with no pressure on them.
