89 crewcab with 6.5TD want to put a nv4500
Discussion in '1982-Present GM Diesel' started by stoney126, May 31, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    hey all, i got a 89 CC with a 6.5 TD and 400 and i believe a 205. I want to replace the turbo 400 with a nv4500. I plan on getting a cummins some time down the line. Crewcab59 told me which year to get, but it was for the 454 i had in my last truck and i forgot anyway :( Anyway what am I looking at part wise to do such a thing and any measurments if some has got em.
  2. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Good to here from ya....
    On the Nv4500 trans get a chevy 96 4x4 or newer,that way you can run the set up you have now.When the Cummins conversion starts,will only need the swap out the input shaft,and get a Cummins bellhousing.
    If you use a dodge now you'll have to swap out the output shaft which the trans has to come apart to use your Gm t-case..
  3. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    the bellhousing should fit right? what else am i gonna need? Also gonna send ya a pm about other stuff
  4. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    You'll need a chevy bellhousing ,Nv4500 trans 4x4 96 or newer,hyd clutch parts ,clutch pedels for the year of thr truck.
    CrewCab59
  5. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    any specifics on the hyd clutch parts cuz i have no idea. And do i need 1 pedal or an entire pedal assembly out of a truck with a manual gear box? Thanks again Crew, looking to maybe head out that way in sept?
  6. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    You need Clutch parts from 86-91 (Truck,Blazer,Suburban).
    Complete hyd clutch pedals,Matser cylinder,slave cylinder,Steel/rubber line,Resevoir Cup and hose.
    To remove the pedal assy to your have to remove the steering colume!
    CrewCab59
