89 GMC Jimmy rear end
Discussion in 'The Garage' started by mrmojo32, Dec 17, 2006.
  1. mrmojo32
    mrmojo32 Registered Member
    Aug 26, 2005
    31
    LOUISIANA
    I have a 1989 GMC Jimmy with a 308 10 bolt rear end. I have located a 1985 3/4 ton Chevy truck with a 456 14 bolt rear end in it. The truck also has front Diff. as well, but is 10 bolt.
    Will these bolt right up to mine? the numbers on the rear end are: N6969
    Any help is greatly appreciated.
    Thanks in advance.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Direct bolt in with the exception of a conversion joint needed for the rear diff.
  3. mrmojo32
    Aug 26, 2005
    31
    LOUISIANA
    Numbers
    What does the N6969 mean?
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I have no idea where you found that number but unless it is the B.O.M. number it probably doesn't mean anything.
  5. mrmojo32
    Aug 26, 2005
    31
    LOUISIANA
    Ok
    Thanks for all your help.
    The guy wants 400.00 for the whole truck minus the motor-trans-bed.
