'89 ignition coil?
Discussion in 'The Garage' started by shaun89, Oct 24, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i got an auto meter tach for my 89 blazer and they said to hook up a wire to the negative side of the ignition coil....i was thinking of a simple coil, but then i saw it and theres 2 plugs and 2 wires going into each...does anyone know which side is the negative side? :confused:
    ps...i dont have a volt-meter.
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    There should be a white pigtail that is like 4 or 5 inches long. Its the smallest wire that doesnt go to the distributor.
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yeah, just follow the wires from the plugs, the white wire that goes into the harness is the one to tap, not the white one to the dist.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There should be a wire hanging off the coil wires that isn't attached to anything, YET, that is the tach sense wire. At least my 89 has the wire already there.
  5. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    awesome, thanks a lot guys, the tach is working stupendus
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Thats what were here for, or pay for, or take advantage of wealth of knowledge
