89 Jimmy brake rotor, hub assembly?
Discussion in 'The Garage' started by Jagged, Apr 15, 2006.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Are the rotors on the front part of the hub, or are they independantly removable?
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Push the studs out with a hammer and punch. Then the rotor and hub come apart. Pull off the rotor. Replace with new one. And use a punch to insert studs.
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Thanks, I'm assuming you remove the dust shield as well to do that?
  4. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    You pull apart the insides of the hub, be it the auto hubs, warn hubs, whatever you got. Then you pull the rotor off the spindle. When you pull it off the spindle all you have is the outer part of the hub and the rotor. The dust sheild remains intact to the spindle on the axle. Set the assymbly on the ground, pound out the lug studs. Put new rotor on. Pound the studs back in. Being SURE the studs seat all the way.
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Mmm convienient time to put new hubs on, thanks a lot for the info.
