89 K5 code 44- but runs rich?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Jun 29, 2002.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I was driving down the highway today and I was having trouble keeping up with traffic, it felt like the motor had no power. It used a ton of gas and it had that rotten egg smell when the cat is clogged. It also has an idle miss (idles rough, hesitates badly from a stop) and it stalled out twice. I think there may be a problem inside the distributor. It doesn't burn any oil, the plugs, plug wires, O2, fuel filter, air cleaner and EGR are new. The SES was not on, but I checked for codes anyway and got code 44 (lean exhaust). The cheesy Haynes manual said I need to check fuel pressure. Where do I hook up the guage? Why would it set a lean code when it is obviously running rich?
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    This is just a guess but maybe the engine thinks it's running lean so it's dumping more fuel than needed, thus creating a rich state. I get code 44 multiple times daily. I need to change the fuel filter and i think it will clear up. I'm not sure on how to hook up the fuel pressure guage. Hope this explains why it's running rich.
    James
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Yeah, that makes sence since limp-home mode is rich, but this is really rich! I'm going to try and find a new rotor and cap tomorow so I can get to work on monday.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I just had the exact same problem with my "89" blazer. I replaced the 02-sensor and nothing, but after I replaced the fuel pump, my problem is all gone now. /forums/images/icons/smile.gif
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I just happen to have a spare fuel pump, I will try that if nothing else works. thanks!
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Is this with your TPI setup?
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">No, it's my 89 K5. I still gotta get the tank in, run the lines and do a few other things before the blue one with the TPI runs. What's a good PC-based scanner program? I might be getting a cheap used laptop this week
