89 K5 Trouble code 24
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, Jun 24, 2003.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Hey Guys,
    My check engine light came on today on my way home from the shop (where my manuals are), and when I got home I pulled code 24 from the ALDL. If anybody has their manuals close by, let me know what it is.
    If not, I will check on it tommorrow. just trying to get a heads up!!
    Thanks Rob
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    autozone.com has online manuals...
  3. dyeager535
    26,982
    191
    Quick search, but most all GM vehicles say thats VSS.
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    how would i check my "code box" to see the reasons my lite lites up? i also have an 89
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Do you mean how do you pull the codes? If its the same as my 87 (im sure it is) you make a paperclip into a U shape, and stick it in the top right 2 holes in ur prom connector. then switch to accesory and it will flash the codes, will flash i believe 12, 3 times then any stored codes.
  6. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    Yup, I bet thats right, because I was fooling around under the truck where the VSS wires plug in to the tranny.
    Thanks Guys!!!
    Rob
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i dont have the k5 here, i'm visiting family... where's the prom connecter?
  8. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    Under the dash just below the headlight switch. Do this with the ignition switch set to accessory (don't start it). The check engine light should flash once then a short pause and flash two more times. This is code 12 (normal). It should flash code 12 3 times, then any other codes will be given in the same manner. I think code 12 is also displayed 3 more times after any error codes.
  9. dyeager535
    26,982
    191
