89 TBI 5.7L cough ?
Discussion in 'The Garage' started by R72K5, Mar 30, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i know locally of an 89 with TBI 5.7L in it and sometimes upon acceleration it will cough out the top end once or twice, pretty much only from dead stop normal acceleration
    any idea what might cause such ?
    im gonna go with new wires and check manifold vacuum with the guage
    also what things can i do or check out on the engine to help it along ? already did replace the plugs and filters.
    thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You say through top end, as in throttle body? Timing perhaps /forums/images/graemlins/thinking.gif Disconnect the wire to distributor and check it. /forums/images/graemlins/k5.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep out the TBI backfire pop on acceleration sometimes, now and then only under load.
    check it in what way with wire disconnected ? you lost me. hehe
    im used to wrenching on carbureted v8 engines, these TBI ones have a wierd HEI and just arent the same as im used to,
    thanks
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There is a wire connector on side of distributor . This runs to computer stuff, to advance or retard. You must pull this before setting base timing. /forums/images/graemlins/k5.gif
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yeah i have heard of people on here saying to disconnect a wire or something going to the distributor, /forums/images/graemlins/thinking.gif but everytime i disconnect anything ay all from the dist, it won't fire at all /forums/images/graemlins/dunno.gif
    It's supposed to be a way to make sure the base timing is set at 0 degrees, haven't messed with mine anymore yet though, as i got it running real good with out doing this, just took alittle longer i would imigine. /forums/images/graemlins/doah.gif
  6. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Not on these TBI's Paul, they are solid connectors with multiple wires going to them, if you pull either of them the whole thing won't fire at all,
    There's supposed to be a wire going to the dist plugs somewhere on the firewall, that supossedly has a quick disconnect on it, but i have yet to find it. That is "supposedly" the wire you disconnect for base timing check.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thanks for the clarification TJ. I heard it on here before, but it does sound like timing. /forums/images/graemlins/k5.gif
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You'll be looking for a tan wire with a black stripe that has an inline WeatherPack connector. /forums/images/graemlins/cool.gif
  9. 4xcrazy
    Oct 31, 2003
    9,471
    5
    /forums/images/graemlins/woot.gif THERE IT IS !! /forums/images/graemlins/woot.gif
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yep, what harry said! It is on the firewall under the brake-booster! Just disconnect it, start up the truck, set base timing to 0* and turn the truck off and reconnect...If it is still missing after you correctly set timing, do a basic tune up; cap, rotor, plugs, wires...Should take car of any misses that could be ingnition related..
    Chris
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok, now i gotcha, yeah instead of having to pull a vacuum advance hose you have to unplug the wire since these are electronic advance, yep.
    thanks /forums/images/graemlins/laugh.gif
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i replaced the cap and wires and i found one big problem, #5 wire was almost completely ripped apart near the boot at the plug end of the wire, /forums/images/graemlins/shocked.gif the wires were the original GM numbered ones with wire loom wrap and all the clips intact and the whole deal,
    the thing is 3.42 axle and 700r4, that first gear is extremely quick, then it kinda doesnt have any power to get going good in second gear and after unlesss you really really get on the pedal hard excessively, runs good but seems like it doesnt put out the low end torque it should have
    also i went through and tightened up all the TBI torx head screws and the three 1/2" TBI unit mounting bolts, everything was loose, some were even finger loose.,
    i see the same thing happen with carb screws so thats why i thought of checking the TBI unit screws.
    apparently this same problem exists with TBI units as did with carbs
    engine is doing better now, just wonder about the lack of torque it seems to produce
    but then it does have 170k on it, and blue smoke puffs now and then lower RPM
    thanks
