89' TBI Throttle Body Cleaning
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Overdrive, Sep 28, 2001.
  1. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    89\' TBI Throttle Body Cleaning
    Any one have any problems/concerns over cleaning a TBI with standard carb cleaner? I just bough the 89' and the unit has some varnish on it. Also, this is my first move from carbed K5's into GM TBI. Any suggestions on care and feeding of the unit? (ie. fuel injector cleaner in the tank every xxx miles).
    Thanks for any info!
    Overdrive
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    Re: 89\' TBI Throttle Body Cleaning
    they make special cleaning spray that is made for TBI or TPI it about the same price as the carb stuff. and i can't remember what the guy a autozone said why it's different but there must be a reason.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Don't know the difference, but I've seen some Valvoline TBI Cleaner in action. 2 bucks a can, has a special cleaing nozzle that looks good, but it works outstanding. I'd definately recommend it.
    Bubba Ray Boudreaux,
    "Tell them the U.S. is coming, and hell is riding with us!!"<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I run a can or 2 of fuel injector cleaner through it evry oil change 3000 mi. lately I have been using Outlaw FI cleaner
    5.00 a bottle and it treats 30 gals. It works good
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    oh man, lucal all the way!!!
    put it in at every oil change (both oil &amp; fuel)...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If you haven't done so already, change the fuel filter. Looks kinda like a soda can with fittings on the ends; it's inside the right framerail near the T-case. Change it regularly and frequently, and you'll avoid lots of problems.
    September 11, 2001--"A date which will live in infamy"
  7. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    I have used carb cleaner on my throttle body. But when your using carb cleaner, look on the can and make sure
    it says "SAFE FOR OXYGEN SENSORS"
    Also,try not to get it on any of the sensors. like the TPS or the IAC
    74 VW Beetle
    84 Pontiac Fiero
    87 Ford Thunderbird Turbo
    83 Honda Nighthawk 550
  8. Overdrive
    Feb 28, 2000
    93
    Gilbert, Arizona
    Thanks for the info guys. I had a few cans of carb cleaner left from my 77 K5. I will just use that on my wife's truck and pickup a couple of cans specifically for fuel injection.
    O
  9. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    WHILE YOUR WORKIN ON YOUR TBI, TRY TAKIN IT OFF THE ENGINE AND CLEANING ALL THE CRUD OUT OF THE PCV INLET.YOU COULD ALSO REBUILD IT WHILE YOU GOT IT OFF,THE REBUID KIT IS PRETTY CHEAP AND IF YOU CAN CHANGE YOUR OIL YOU CAN REBUILD A TBI.
