89 tranny swap
Discussion in '1983-2005 S-Series models' started by mudslinger6, Jan 2, 2005.
  1. mudslinger6
    mudslinger6 1/2 ton status
    Aug 1, 2004
    125
    live in ct by the mass line
    i have a 700r4 from my 89 fullsize and i just bought that 89 s-10 with a 4.3 i was told that the 700r4 will bolt up??or is there another tranny that will fit turbo 400??th350??im am just making sure because if so i am starting to tackle the issue in the next few days i need to badly get my 83 camaro off the road:( thanks for all the help
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Externally they're the same. :) Internally the V8 version has a few more clutch plates, so it should last a long time behind a V6.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the v8 version and the 4.3 version are identical in everyway, it was the 2.5 and 2.8 that got fewer clutches.
    the 4.3 has the same bellhousing pattern as a 350 so they will all work, just have to move the tranny crossmember
  4. mudslinger6
    Aug 1, 2004
    125
    thanks
    so i can use a th350 or a 700r4 tranny then??? thanks for the help
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can use a 700r4, th350 or th400
  6. mudslinger6
    Aug 1, 2004
    125
    thanks alot i need to get my camaro off the road and with that info it will be by wensday
