89& up 10 bolt or d44 (both W/31 spline axles) ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bassmannh, Feb 22, 2004.
  1. bassmannh
    bassmannh Registered Member
    Jun 8, 2003
    18
    Do any of you guys have an opinion on which is better,stronger. Both have 31 spine axles, but Ive heard that the newer 10 bolts (89&up) have a stronger/larger pinion shaft diameter and bigger bearings, can anyone give me more info, I am in posession of both of these axles, the 10 bolt is currenly in my sub, (91 GMC) should I leave it and sell the d44, if the d44 had flat top knuckles it would be an even harder decision..what do you all think???
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The stock carrier for the 30 spline 10 bolts are known to be weak. That is the only knock on the 10 bolt vs. D44. If the 10 bolt is already there leave it in my opinion. I run a 28 spline 10 bolt. Swapping to a D44 has no strength advantages for the most part over the 10 bolt. People will argue that they do but the weakest point of both axles is the 297X ujoint that BOTH axles run.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Both axles should have 30-spline axles, not 31. I really don't think one has any advantage over the other unless one has the gear ratio you want....otherwise it's not worth the swap.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    With a detroit and alloy axles, it can be strong. No point in doing that to a 10 bolt though.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    D44s with flat top knuckles have smaller wheel bearings, weaker hubs, and in some cases, a 260x u joint.
    Your best bet is probably a combination of the two axles. /forums/images/graemlins/thumb.gif Use the 10 bolt, but put the flat top knuckles and tie rod on it.
