89 v3500 sb... reverse rotation waterpump?
Discussion in 'The Garage' started by camiswelding, Mar 8, 2005.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Since my truck is in a million pieces I was wondering if anyone can confirm the 89 sb v3500 has a reverse rotation waterpump.. I believe it does but I cant remember
    thanks
    cam
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Should be conventional rotation. My '91 V3500 was. Pump turns same direction as crank.
    Reverse rotation pump got used with trucks that had a single serpentine belt and belt tensioner. Pump turns opposite direction as crank.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    My 89 2500 has the single serp belt and reverse water pump...
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Which body style?
    FWIW, my 91 V3500 has a standard rotation water pump. If I remember correctly, the original motor in my 91 K5 had a serpentine belt set up with a reverse water pump.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Sorry, mine is a new body style with IFS... It's technically a heavy half.
  6. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks everyone....
    I concur now... standard roatation.... thanks for helping me figure it out
    cam
  7. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    my 89 3500 crew cab old body style has single sepr belt and is rev. rot. water pump.:)
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Regardless of year, if it has V belts it is standard rotation, if it has a single serpentine belt it is reverse rotation. :deal:
  9. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    It would be interesting to know why trucks of the same body style and similar years have different belt configurations. :thinking:
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    Engine size may be a factor?
    My '91 V3500 (350 TBI) had one v-belt and one multi-groove (serpentine) belt. Conventional rotation water pump.
    EDIT: No smog pump, or AC either.
  11. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    My 91 crew cab is set up the same as yours with the "v" and multi groove belts (with a/c, no smog) but my 91 K5 originally had a 350 with the serp system (with a/c, can't remember if it had a smog pump).
    Maybe a smog pump is the difference? :thinking:
  12. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    ditto for me... with a/c.... multi groove and 1 v belt
    about this time in production gm was thrwoing anything lft over from the gen 2 production run into the mix....
    1/2 metric 1/2 standard
    thanks everyone
    cam
