89 vacuum Question??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stickseler, Mar 31, 2001.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    While I was checking my vacum lines under the hood of my 89 350 TBI I found a bad one on the ball next to the fire-wall on the jack side. It goes into a tee that goes into a switch (?)on one side that goes somewhere behind the dist. before the swith is a line thats "capped off" the other line off the tee goes into the fire-wall on the passengerside. What's the ball and swith and where does it go. Also is there somthing besides a haynes manual for an 89..It does not have much about TBI?? Thanks..
    '89 350TBI, Stock w/ 220,000 Miles Running Strong
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Re: 89 vacum Question??
    I'm not sure about the ball and switch without looking at mine. I have an 89 Jimmy and was looking for a manual but all I could find is the Haynes. They do make a manual on fuel injection though. If you find a manual other then the haynes let me know.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  3. Grim-Reaper
    7,385
    Atlanta
    That Ball is a Vacume Resivior for the Heat and A/C controls. The Switch has something to do with either emmisions controls (think it signals enough throttle buy vac drop to either kick in the EGR I Think it could also be a signal switch for the distributor advanced as everything you have described is also on 80's non EFI trcuks). It connects to the manifold in front ot of the distributor. The other line that I think your refuring to is probably going to the Cruise control throttle control.
    Look under heat and a/c controls and Cruise controls and emissions in your book That shoud all be the same for any of the after 85 trucks (most of it's the same for ALL trucks with the same options).
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
