8inch lift?
Discussion in 'The Garage' started by 4x4k20, Jan 27, 2005.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    thinking of going with a 8inch spring lift.on my 79 k20 with dana 60 up front . what kind of problems should i expect to run into when installing it? or should i go with a 6?
  2. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    As far as the front goes 6" springs will probaly flex alot better. and if you need more lift than that go with some ORD shackles that give you 1" or a set of ORD Zero-Rates that can give you another inch. In the rear, most people on this site like the shackle flip set up for flex. What size tire are you planning for?
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    8" springs are not the most flexible. Problems you will run into are driveshafts length and angles of the pinion's. I am running a 6" with zero rates front and rear as well as a 1" body lift to get my 8". The 6" are not that flexible either but work for what I do. I didn't have any problems with my driveshafts due to I am running a fixed yoke 203 but still there are others that will need to have their shafts extended. I had to extend my front shaft when I moved the front axle forward 1.5" but was fine until I did that.
  4. gridfaniker
    gridfaniker Banned
    Jan 27, 2005
    25
    Rexville, NY
    there's this guy named builder. An eight-inch lift wouldn't even make him flinch.
  5. KrackMonkey
    KrackMonkey Banned
    Jan 27, 2005
    11
    Bangladesh
    That guy is a legend in my parts. Word is, he comes through once a year, but I seem to miss him every time he comes through.
  6. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i dont think the ORD shackels give you 1 inch lift, i think they are 1 inch longer than stock shackles to keep the spring eye off the frame and only provide about a 1/4 inch of lift
  7. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    that is correct info on the shackles !!!!! i have them and do agre
  8. Larry McMurray
    Larry McMurray Banned
    Jan 26, 2005
    12
    Shelby, NC
    Don't he drive that little rig he nickname Topher? Or is this a different guy?
  9. double_penetration
    double_penetration Banned
    Jan 27, 2005
    5
    south of heaven
    Daisey, I got 8 inches for you.
  10. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    Wow, that is classy. Get a clue! :waytogo:
  11. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Shackles arent the best thing to use if yer looking for lift because they angle yer pinion down. I'm working on an 8" lift for my truck, 4" rear springs with ORD shakle flip and 1" zero rate(9" total rear), I figure after a lil bit the springs will sag down and even out with the front 8" springs. If the rear sits higher I migth consider a set of 1" zero rates there as well.
    A well built high angle shaft will work just fine. High Angle DS is definately top of the list but they arent cheap. Check out http://www.arizonadrivelines.com/ . I have seen some of there work and its pretty decent for the price. Bout 325 for a high angle shaft with 1350 yokes.
