8lug wheel size
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skelly1, Dec 15, 2002.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    If you upgrade to 8 lug 1 ton axles, can you use 15" wheels? I've heard that you can very easily lose your bead with low pressure on the 16.5" wheels. I also have brand new 15" tires that weren't cheap.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Yes, but you will have to grind the calipers on the front. There is a write-up about caliper grinding on here under tech articles.
  3. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Thanks. The tech article covers the D60. Is the D44 the same situation?
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The only 1 ton axle is a D60. If you mean an 8 lug 3/4 ton D44 then you do not need to do anything, your 15" wheels will fit just fine.
  5. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Beautiful. Even aluminum wheels?
    I'll have an easier time finding a 3/4 ton donor than a 1 ton, and that should suffice, since I can get a 14bolt from a 3/4ton and a D44 is good too.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Yes, even aluminum wheels
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I had to gring on my 3/4 ton D44. I believe you have to grind on all 8 lug front axles to fit 15's.
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I made a 8-lug to 6-lug ring to keep my 6 lug rims, you can check it out on my web page,just hit the link on the bottom...
  9. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    [/ QUOTE ] \
    It will fit it your keep your backspacing low.
    I have approx 4" backspacing and had to grind the calipers on my old 3/4 ton front axle.
    -- Mike
  10. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    I couldn't get to your webpage. More info on the 8 to 6 lug rings would be cool.
    I'm not sure what kind of backspacing my rims have right now. I just know that they are 15X10 aluminum.
  11. TONYP
    Aug 13, 2002
    2,116
    so cal
  12. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I don't think so. As far as I've heard, steel rims are a tight fit. There's no way you can fit 15" aluminum rims on a 3/4 ton dana 44 without grinding an unsafe amount of material off your caliper. Sorry for the bad news.
