8lug wheels
Discussion in 'The Garage' started by TXsizeK5, Dec 9, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    does anyone know what the cheapest , but decent, 8 lug rim would be? Who makes it and who sells it? Thanks!
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I bought mine from 4WPW for $50 each.
    Discount tire sells, I've heard, a similar one for $30.
    -- Mike
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    you might want to peek at these guys.. When i put in my 14bolt, it was a simple way to move to 8lug.. for not too much $$$ Truck-n-Rv Supply
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Send Steve (coloradok5) a PM and ask him. He can prolly get them thru his Off Camber 4x4 site. /forums/images/graemlins/thumb.gif
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Try www.summitracing.com ,they have 15x8's steel 8 luggers for $26.95 each,$6.95 handling and free shipping.That's $114.75 for four wheels shippied to your door.Mike
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    K, another queston... how do you know how much backspacing you have? and can you fit 15" rim on 14bff? Thanks
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Okay, yes the steel 15" rims will fit over a 14 Bolt FF.(Don't know about Alu.) If you wanta line your tires up (front axle is wider then rear axle) you would use 4" back spacing for the fronts and 2.5" back spacing for the rears. Recomend your spare be 4" back spacing. Better to look weird on the rear with the spare the rubbing up front with the spare.
  8. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    WHat would diff be between the steel and aluminum and chrome? (fitting a 14bff wise)
  9. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Aluminum requires a thicker amount of material to provide the same strength as steel. This means that the thicker 15" will have a smaller inside diameter, MAYBE not fitting over the drum.
    Chrome wheels are steel wheels, just with a pretty finish. Those will fit fine.
  10. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Aah, you learn something new everyday. Especially here /forums/images/graemlins/thumb.gif
  11. CK5
    May 19, 1999
    21,622
    701
    CO
    I will check pricing, not sure I could beat that Summit price though, holy cow. /forums/images/graemlins/eek.gif
  12. REDMANIAC
    REDMANIAC Registered Member
    Oct 19, 2001
    40
    WHEELS OF STEEL
    Check the pricing, plus custom backspacing only $5each wheel, best price Ive found so far, just recv'd my 15x10 2.75in BS 8luggers(the WS1's-black) /forums/images/graemlins/usaflag.gif
