8mm Hex Head Wrench
Discussion in 'The Tool Shed' started by Brodie, Dec 3, 2006.
  1. Brodie
    Brodie 1/2 ton status
    Mar 20, 2006
    255
    Puyallup, WA
    My truck has an Edelbrock Torker II intake manifold on it currently. I am trying to remove it and have run into a snag. The mount bolts on it are a 8mm Allen Key, and the middle 4 bolts are impossible to get at because of the design of the manifold. Is there a special wrench that is needed to get them out? I've tried 5 different 8mm wrenches and 2 different 7mm (trying to wedge it at an angle). Please help a brotha out.
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    How about a pic of said situation?
  3. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    As you can see, I already tried Vise Grips. The bit in the second picture is just for scale. I also have regular Allen Wrenches and they don't fit either.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You can't use an allen socket, you're going to need a L shape allen wrench.
    When you do finally get them off use ARP bolts, nice quality bolt kits.
  5. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    A ball hex would probably be best...
    Something like this...
    You may be able to sneak a straight L shaped, regular allen head in too as 4x4high mentioned...
    edit... damn cornfed :wink1: , ya beat me to it... :doah: :haha:
  7. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    I already tried the L-type, and no love. Looks like it's all about the balls:D
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    hehe, nice...
    yeah, that should work... I don't own the long ones, but the standard lengths have come in handy on a few occasions...
  9. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    those bolts are mostlikly hardened.
    but a last try efort. if you dont under stand this one dont try it at all.
    take a hammer and chissle or best bet air hammer with chissle bit. the bits need to be sharp. then try and spin the bolt loose with the impact of the chissle in the side face of the bolt.
    i have used this trick on many drain plugs and others. best works with air hammer tho.
  10. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Take the bit out of the allen socket, use a box end wrench to fit the allen insert and loosen the bolt.
  11. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Or maybe heat up an L shaped allen and bend it to fit in there..
  12. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Take said "L-shaped" :haha: allen wrench and grab your hacksaw-cut-off tool-portaband and trim said "short" side of wrench to fit in said confined space.
    Once you have it loose, the ball end wrences will probably work to get it out.
    But if you don't get it loose with a tool that fits good, you be in a world of hurt trying to get rounded allen bolts out of that spot.
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    That IS what they are called...
  14. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    Tried taking the bit out. It still didn't fit
  15. chevyfumes
    Feb 24, 2000
    38,584
    266
    :doah: Hacking off the end of one is the easiest idea so far though...Kinda like the little girl coming up with the idea of letting the air outta the big trucks tires to release it from the tunnel, garlicbreath is "our" little girl now...:haha: :D
  16. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
  17. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    It just came across as him thinking that was the incorrect term for the tool, when it really is..
    Now if Brodie had ball hex sockets, he wouldn't have even needed to make this thread.... I'd certainly rather just use my socket than bother hacking up an allen wrench..
    Now go back to quivering under the dining room table! :wink1:
  18. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I figured they may be a little long, thus why I didn't post em. I own metric and standard in those, handy and affordable..
    You may need to leverage the short end of those to get enough torque on the ball end, if they're stubborn...
  19. chevyfumes
    Feb 24, 2000
    38,584
    266
    I think he was trying to bust our balls for using the L shape term, thats why he has now been dubbed the official Tool girl of CK5...And I have my bottle and ice and mixer under the computer desk as we speak, along with an AR15...:haha: :haha: :haha:
  20. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    If its a metric Hex.............the threads on the bolt are metric too.
    I highly doubt the tapped holes in the SBC head are metric. so in reverse logic you need a standard allen wrench.
